Baking to texture Max 2021
By Remy · 2021-03-18
So i'm working with this script to bake all the textures to export it as fbx eventually. It's a script that is used here:
https://www.youtube.com/watch?v=xBYkVS3ctbo
Unfortunatly it does not work yet on my mesh models. I'm getting an active render error and i'm not sure what it means. It won't render the completemap. We use vray. Hoping for some help. And perhaps other people can use it then too.
SCRIPT:
-- capture selected objects
selectedObjectsAll = deepcopy (selection as array)
selectedObjects =#()
for a in SelectedObjectsAll do
if (superclassof a == GeometryClass) then append SelectedObjects a
-- clear up the BTT list
BakeToTexture.deleteAllMaps()
BakeMaps = #()
-- get the project folder and set the destination folder for the MapScaler
BakeToTexture.outputPath = pathConfig.getCurrentProjectFolder() + "\\sceneassets\\images"
-- adds a complete map in 1024x1024 for all my selected objects and set it to map channel 2
for a in SelectedObjects do
-- if there is no UV channel 2, create One
if (meshop.getMapSupport a.mesh 2) != true then
select a
max modify mode
NewModifier = Unwrap_UVW()
addmodifier a NewModifier
a.modifiers[1].setMapChannel 2
a.modifiers[1].setApplyToWholeObject true
a.modifiers[1].flattenMapNoParams()
a.modifiers[1].pack 2 0.001 true true true
subObjectLevel = 0
deselect a
TheNewMap = BakeToTexture.addMap a #CompleteMap
TheNewMap.imageWidth = 1024
TheNewMap.imageHeight = 1024
TheNewMap.uvChannel = 2
append BakeMaps TheNewMap
-- bakes the Maps
BakeToTexture.bake()
-- moves the UVs from channel 2 to channel 1 so that the objects can use the complete map on channel 1
for a in BakeMaps do
ChannelInfo.CopyChannel a.sceneObject 3 2
ChannelInfo.PasteChannel a.sceneObject 3 1
a.sceneObject.material = Physical_Material()
a.sceneObject.material.base_color_map = bitmaptexture()
a.sceneObject.material.base_color_map.filename = (BakeToTexture.outputPath + "\\" + a.filetype)
-- put the rendered images in th diffuse slot of all my materials
ERROR:
-- Error occurred in anonymous codeblock; filename: X:\stockpoint - 3D\Scripts\Maxscript\BF Tools\mcr\Development\bf_BakeToTexture\bf_BakeToTexture_01.ms; position: 1169; line: 41
-- Runtime error: Cannot add the map. This map type #(65537, 0) is incompatible with the active renderer, or the specified class ID is not valid.
-- MAXScript callstack:
--thread data: threadID:29068
--[stack level: 0]
--In a loop; filename: X:\stockpoint - 3D\Scripts\Maxscript\BF Tools\mcr\Development\bf_BakeToTexture\bf_BakeToTexture_01.ms; position: 1048; line: 36
--member of: anonymous codeblock
--Parameters:
--a: $Editable_Mesh:wiremesh @ [34087.792969,27623.830078,93.220917]
--Locals:
--NewModifier: Unwrap_UVW:Unwrap UVW
--TheNewMap: undefined
--Externals:
--subObjectLevel: SystemGlobal:subObjectLevel : 0
--BakeMaps: #()
--owner: <CodeBlock:anonymous>
--[stack level: 1]
--called from anonymous codeblock; filename: X:\stockpoint - 3D\Scripts\Maxscript\BF Tools\mcr\Development\bf_BakeToTexture\bf_BakeToTexture_01.ms; position: 1170; line: 41
--Locals:
--selectedObjects: #($Editable_Mesh:wiremesh @ [34087.792969,27623.830078,93.220917], $Editable_Mesh:Circle048 @ [34138.640625,27628.189453,66.239578], $Editable_Mesh:Canvas002 @ [34155.617188,27617.250000,81.204674], $Editable_Mesh:Lijst002 @ [34155.617188,27617.250000,81.204674], $Editable_Mesh:Canvas003 @ [34174.394531,27607.175781,64.950714], $Editable_Mesh:Lijst003 @ [34174.394531,27607.175781,64.950714], $Editable_Mesh:Tafelpoot Florance @ [34159.011719,27627.054688,25.955999], $Editable_Mesh:Tafelpoot Florance @ [34159.011719,27627.054688,25.955999], $Editable_Mesh:Tafelblad florance @ [34159.011719,27627.054688,22.475920], $Editable_Mesh:Tafelpoot Florance @ [34159.011719,27627.054688,25.955999], $Editable_Mesh:Tafelpoot Florance @ [34159.011719,27627.054688,25.955999], $Editable_Mesh:Tafelblad florance @ [34159.011719,27627.054688,64.382820], $Editable_Mesh:Tafelblad glas florance @ [34159.011719,27627.054688,65.943672], $Editable_Mesh:O-Luce - Atollo - lamp frame @ [34168.445313,27642.119141,123.153961], $Editable_Mesh:O-Luce - Atollo - lamp @ [34167.109375,27643.052734,3.342739])
--selectedObjectsAll: #($Editable_Mesh:wiremesh @ [34087.792969,27623.830078,93.220917], $Editable_Mesh:Circle048 @ [34138.640625,27628.189453,66.239578], $Editable_Mesh:Canvas002 @ [34155.617188,27617.250000,81.204674], $Editable_Mesh:Lijst002 @ [34155.617188,27617.250000,81.204674], $Editable_Mesh:Canvas003 @ [34174.394531,27607.175781,64.950714], $Editable_Mesh:Lijst003 @ [34174.394531,27607.175781,64.950714], $Editable_Mesh:Tafelpoot Florance @ [34159.011719,27627.054688,25.955999], $Editable_Mesh:Tafelpoot Florance @ [34159.011719,27627.054688,25.955999], $Editable_Mesh:Tafelblad florance @ [34159.011719,27627.054688,22.475920], $Editable_Mesh:Tafelpoot Florance @ [34159.011719,27627.054688,25.955999], $Editable_Mesh:Tafelpoot Florance @ [34159.011719,27627.054688,25.955999], $Editable_Mesh:Tafelblad florance @ [34159.011719,27627.054688,64.382820], $Editable_Mesh:Tafelblad glas florance @ [34159.011719,27627.054688,65.943672], $VRayLight:VRayLight001 @ [34168.445313,27642.119141,119.625076], $Editable_Mesh:O-Luce - Atollo - lamp frame @ [34168.445313,27642.119141,123.153961], $Editable_Mesh:O-Luce - Atollo - lamp @ [34167.109375,27643.052734,3.342739])
--BakeMaps: #()
--Externals:
--[stack level: 2]
--called from top-level
Sam Large
Complete Map is incompatible
I realise I'm months late to the party on this, but the error suggests that the Complete map is incompatible with VRay, have you tried using the VRayCompleteMap instead?
Sam Large
