Backburner, script, name issue. Help please.
By Dariusz · 2015-07-23
Heya I'm trying to send my job to BB and get a right name output out of it. This is my basic test command :
m =NetRender.GetManager()
m.connect #automatic "255.255.255.0"
job = m.newjob ()
job.useAllServers = true
job.name = "aaaa" job.fromFrame = 0
job.toFrame = 0
job.submit()
And I forgot what is the damn command code again to wrap text
Anyway the name output I get is something like "Name_test0000.ext" where as I want "Name_test.ext"
Can any1 please help me out? I'm running out of options here as to how to tweak up the code so it gives me the correct result.
Comments (7)
Dariusz
Yeah
even when I try :
job.frames = ("0")
Give me 0000. I just dont know what is the command to submit single frame. Or maybe should I just leave it empty O_O
Reply to pixamoon
Dariusz
Hey
Yes I did see his post. Sadly its a little bit hard to go over his script + its hist script. Isn't there a simple command am I just missing?
Dariusz
HeyYeah I know how tos cript
Hey
Yeah I know how to script rename script. The problem is that. I send the job to backburner via script. Which creates 20 000 jobs. They are then being rendered and I end up with up to 60 000 render images.
Cant have another script running really. I would need BB to save the file properly with no 0000 at the end.
When I submit job manually from max to network it will save job as "Name_test.ext" so there must be a way to script submit job and not have the extra 0000....
Reply to Dariusz
pixamoon
do you want to submit animation or single frames ?
if single frames (and u don't need 0000 on the end) problem can be in:
job.fromFrame = 0
job.toFrame = 0
It looks like you submitting it as animation job frame 0 to 0. I think that's why BB adds 0000 on end of rendered images.
pixamoon
hey,
If you want to remove 4 last digits from name try this:
oldName = "Name_test0000.ext"
f = getfilenamefile oldName
t = getfilenametype oldName
newName = (substring f 1 (f.count - 4)) + t
or to get render output filename :
rendOutputFilename
