for the selected camera there is an option to enable MultiPass Camera Effect
$.mpassEnabled = off
but, with this inclusion, is used Deph of Field effect...
is there a command to automatically enable to Deph of Field (mental ray/iray) effect ???
By andrej · 2019-01-09
Thanks so much. The help does not describe this feature....
you can always use show $ to print object properties in listener
first I checked what $.mpassEffect returns and then what it returns after I manually change it to mr mode.
then just assign a new instance of dof mode as shown above
thank you for the lesson....
another question??? Why spinners do not work
try (DestroyDialog Test) catch()
utility Test "foo" width:100 height:50
spinner spn_TDist "Dist" range:[0,1000,1]
spinner spn_F_Stop "F_Stop" range:[0,10,1]
on Test open do
$Camera001.mpassEnabled = on
$Camera001.mpassEffect = Depth_of_Field__mental_ray()
on spn_TDist changed val do
$Camera001.targetDistance = val
on spn_F_Stop changed val do
$Camera001.mpassEffect.f-Stop = val
createDialog Test pos:[100,100]
yeah, I didn't learn my lesson...
