Hello
i have old script which instance certain modifiers with same names different from default ones.
for example if both Shell modifiers on two objects to Shell_Glass - two objects will get instance Shell modifier Shell_Glass
this script supposed to be in scripts/startup folder but apparently not working in max2014/ any chance to fix it?
thank you in advance
now i see! macro is working
it is working as macroscript. need to off/on button (re-activate script) when working new set of objects.
have a better idea -is it possible at all? to rename two same type modifiers in order to instance them. or clone object as Copy with custom named modifier will cause Copy but with instanced modifier.
will appreciate for any help.
The script works when the name of the object is changed.
thanks, but not working
nothing happens when i rename both modifiers. unfortunatelly i dont remember way it worked before. was soooo long time ago)
I don't have time to test it, but try only with this part:
By the way, the script, as you posted is not for the startup folder. It have to be used as macro for toolbar button/hotkey.
script
local isOpen = false
on execute do
if isOpen == true then isOpen = false else isOpen = true
deleteAllChangeHandlers id:#nameChange
when names geometry changes id:#nameChange do
if getCommandPanelTaskMode() == #modify do
curMod = (modPanel.getCurrentObject())
cnt = true
for i in geometry where i.modifiers[curMod.name] != undefined while cnt == true do
replaceInstances selection[1].modifiers[curMod.name] i.modifiers[curMod.name]
cnt = false
else (deleteAllChangeHandlers id:#nameChange)
on isChecked do
if isOpen == false then return false else return true
