Attribute_Holder 2 help
By othoap · 2008-08-28
Running max r9 sp3
I get this error :
__________________________________________________________________
OK
OK
Compile error: redefine: must be an attributes definition value, in
cons
In line: redefine:ravinCtrl
___________________________________________________________________
I
have a “circle” selected with a “Attribute_Holder 2” mod on
it. When I run this script:
global
ravinCtrl
for
numDef = 1
to
(custAttributes.count $.modifiers[1])
do
    print
(custAttributes.get $.modifiers[1] numDef).name
    if
(custAttributes.get $.modifiers[1] numDef).name ==
"cons"
then
        ravinCtrl
= (custAttributes.getDef $.modifiers[1] numDef)
  ravinCtrl
Attributes
"cons"
    redefine:ravinCtrl
        parameters
mainP
rollout:mainR
        noseGear
type:#float ui:(spinNose,slideNose,angNose)
            rollout
mainR
"cons"
            spinner
spinNose
width:50 height:16 range:[-180,180,0] pos:[98,14]
            button
resetNose
"reset"
width:40 height:14 pos:[53,15]
            slider
slideNose
width:111 range:[-180,180,0] ticks:0 pos:[55,30]
            GroupBox
grp1
"NoseGear"
width:158 height:53 pos:[3,2]
            Angle
angNose
diameter:37 range:[0,360,90] startdegrees:0 dir:#cw color:white
pos:[9,15]
            on
ang changed spinNose
do
spinNose.value = spinNose
            on
resetNose pressed
do
                    spinNose.value
= 0.0
                    slideNose.value
= 0.0
custAttributes.add
$.modifiers[1] ravinCtrl
Any
thoughts?
