Attach xref scenes from txt file?
By squeakybadger · 2017-04-25
Hi all,
I'm trying to load a few xrefs from a text file (that will dynamically change content in the future)
This is my code, it seems to read the text file but throws up and error and doesn't attach anything:
xrefPath = "c:\\users\\jaime\\desktop\\x\\"
ext = ".max"
listArray = #()
file = openFile "c:\\users\\jaime\\desktop\\x\\xrefs.txt" mode:"r"
while not eof file do
lineInfo = readLine file
append listArray lineInfo
close file
for i in listArray do
xrefs.addNewXrefFile (xrefPath + i + ext) i
This is the error in the listener:
"c:\users\jaime\desktop\x\"
".max"
<File:c:\users\jaime\desktop\x\xrefs.txt>
#("temp.max", "vbnv.max", "scriptest.max")
OK
-- Error occurred in i loop; filename: ; position: 314; line: 15
--  Frame:
--   i: "temp.max"
-- Runtime error: Unknown addNewXRefFile argument: "temp.max"
Any ideas on what's wrong?
Thanks.
This:
"temp.max"
must be a full path to the file. Something like this:
"D:\\Projects\\temp.max"
So, in the text file you should have written the full paths to the files, not only the name of the files that you want to attach to the scene.
