I can't get this function working on 3ds Max 2010 Design SP1.
The manual function named "Make Path Absolute" works...
Can someone help me to find another way to do the same task?
clearlistener()
function fn_SetAssetsWithValidPath =
Correct the path in the Asset Tracking system with the status found
status "found" = Max find the asset but the path is not valid
ATSOps.CheckNetworkPaths = true
ATSOps.Refresh()
ATSOps.GetFiles &aAssets
local aAssetsWithFoundStatus = #()
local aOutputAssetsWithOkStatus =#()
for i = aAssets.count to 1 by -1 do
local ss = ATSOps.GetFileSystemStatus aAssets[i]
if ss[1] == #Found then
append aAssetsWithFoundStatus aAssets[i]
print ss[1]
if (ATSOps.IsInputFile aAssets[i]) == false then
if ss[1] == #Ok then (append aOutputAssetsWithOkStatus aAssets[i])
join aAssetsWithFoundStatus aOutputAssetsWithOkStatus
if aAssetsWithFoundStatus.count > 0 then
ATSOps.Silent = true
ATSOps.Visible = true
ATSOps.ClearSelection()
ATSOps.SelectFiles &aAssetsWithFoundStatus
ATSOps.ResolveSelectionToAbsolute()
--ATSOps.Visible = false
-- for i = aAssets.count to 1 by -1 do -- recurse cuz of buggy function!
-- if ATSOps.TestFileSystemStatus aAssets[i] #Found then (fn_SetAssetsWithValidPath())
print aAssetsWithFoundStatus
replace then with do
replace (then) with (do) in this line
Hey,
Did you manage to fix it?
I'm trying to achieve something similar.
Regards.
