I have made a script that will export selected obj(s) name(s) and a given number to the listner
100, mybox
101, mybox2
etc
What I want to be able to do is, import that info from an external text file (ie my example, saved previously from listener to desktop)
and apply the numbers to the objects (in this case mybox & mybox2) in the scene. so I can then write that info with some other data to the listener with another script at any time I select them.
What I really want to know is how would I permanently assign a number to an obj and how would I be able to call it?
hope this makes sense
thanks for any help
each node has build-in unique identifier, so you can get it with ".handle" and find your obj with
function.
Sorry Im new at this. by using that I can change the handle value to one from an imported text file and read that number in another script?
I tried inode.handle which seemed to be the number of the object (in order it was created) in the scene but everything I tried come back as non writable or read only, something along those lines.
how do I assign a number to it and read from it? or are there empty handles I should have used?
Hi Smallface,yes, node
Hi Smallface,
yes, node handle ID is read only auto-enumeration.
I hope this help.
P.S. - if you look for your own independent enumerator (not controlled by Max), check in the help 2 possibilities:
or
Cheers
Anubis
User-Defined properties (getUserProp, setUserProp, ...)."
This seems to be exactly what Im after. thank you.
