Assign random wirecolor to object
By nguyenthanhtung3d · 2016-10-06
Hi all
I'm looking for a script that can assign random wirecolor to each object in the scene in order to create a good wirecolor passes. Any clue ? Please help me out
Thanks in advance !
fajar
miauu simple one liner in 242 objects....
</p>
<p>sel = selection as array<br>clearSelection()<br>t=timestamp()<br>h=heapFree<br>rdm=random <br>for o in sel do o.wirecolor = rdm black white<br>select sel<br>format "Done it in :% | RAM : %\n" ((timeStamp()-t)/1000.) (heapfree - h)</p>
<p>--Done it in :0.059 | RAM : -4616L</p>
<p>
swordslayer
</p>
<p>fn shuffle &amp;arr =<br>(<br>&nbsp;&nbsp;&nbsp; local temp, swapIndex, counter = arr.count + 1<br>&nbsp;&nbsp;&nbsp; while counter &gt; 1 do<br>&nbsp;&nbsp;&nbsp; (<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; swapIndex = random 1 (counter -= 1)<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; temp = arr[counter]<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; arr[counter] = arr[swapIndex]<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; arr[swapIndex] = temp<br>&nbsp;&nbsp;&nbsp; )<br>&nbsp;&nbsp;&nbsp; OK<br>)<br><br>fn incrementCounters &amp;r &amp;g &amp;b step =<br>(<br>&nbsp;&nbsp;&nbsp; if (b += step) &gt; 256 do<br>&nbsp;&nbsp;&nbsp; (<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; b = 1<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if (g += step) &gt; 256 do<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; (<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; g = 1<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if (r += step) &gt; 256 do r = 1<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; )<br>&nbsp;&nbsp;&nbsp; )<br>)<br><br>fn assignRandomWirecolor objs simple:true =<br>(<br>&nbsp;&nbsp;&nbsp; local stepCount = objs.count^(double 1/3) + 1<br>&nbsp;&nbsp;&nbsp; local step = 255./stepCount<br>&nbsp;&nbsp;&nbsp; local redArr = #(0) + #{1..255}<br>&nbsp;&nbsp;&nbsp; local greenArr = copy redArr #noMap<br>&nbsp;&nbsp;&nbsp; local blueArr = copy redArr #noMap<br>&nbsp;&nbsp;&nbsp; local r = local g = local b = 1<br><br>&nbsp;&nbsp;&nbsp; if simple then<br>&nbsp;&nbsp;&nbsp; (<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; shuffle &amp;redArr<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; shuffle &amp;greenArr<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; shuffle &amp;blueArr<br>&nbsp;&nbsp;&nbsp; )<br>&nbsp;&nbsp;&nbsp; else shuffle &amp;sel -- slower with many objects<br><br>&nbsp;&nbsp;&nbsp; for obj in objs do<br>&nbsp;&nbsp;&nbsp; (<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; obj.wirecolor = [redArr[int(r)], greenArr[int(g)], blueArr[int(b)]]<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; incrementCounters &amp;r &amp;g &amp;b step<br>&nbsp;&nbsp;&nbsp; )<br>)<br><br><br>sel = selection as array<br>clearSelection()<br>t=timestamp()<br>h=heapFree<br>assignRandomWirecolor sel --simple:false --&gt; if simple is not so cool, try the other option<br>select sel<br>format "Done it in :% | RAM : %\n" ((timeStamp()-t)/1000.) (heapfree - h)</p>
<p>--Done it in :0.064 | RAM : -20432L</p>
<p>
for o in objects do o.wirecolor = random black white
