Hi all,
I am trying to get a simple piece of code to work but it gives me an error
--Unknown property: "Checked" in "chk0"
I want the script to add the number of each checked checkbox to an empty array (see line 28)
I think my issue is that chk0 is a string in my script and thus I get the error.
This should be a simple error on my side but I am not sure how to fix it.
rollout Test "Test" width:300 height:803 ( --start of Rollout Exporter
--INCLUDE USER INTERFACE HERE
button btn_test "Test" pos:[18,14] width:116 height:60 toolTip:"If 'overwrite name' option is not used; obj name of currently selected obj will be used"
groupBox grp1 "Export Options" pos:[150,7] width:151 height:439
checkbox chk0 ".max 0" pos:[160,25]
checkbox chk1 ".3DS 1" pos:[160,50] width:137 height:23
checked:true
checkbox chk2 ".AI 2" pos:[160,70] width:137 height:23
checkbox chk3 ".DWG 3" pos:[160,90] width:137 height:23
checkbox chk4 ".DXF 4" pos:[160,110] width:137 height:23 checked:true
checkbox chk5 ".STL 5" pos:[160,130] width:137 height:23
checkbox chk6 ".SAT 6" pos:[160,150] width:137 height:23
checkbox chk7 ".PxProj / .NXB 7" pos:[160,170] width:137 height:23
checkbox chk8 ".FBX 8" pos:[160,190] width:137 height:23 checked:true
checkbox chk9 ".DAE 9" pos:[160,210] width:137 height:23
checkbox chk10 ".IGS 10" pos:[160,230] width:137 height:23
checkbox chk11 ".WIRE 11" pos:[160,250] width:137 height:23
checkbox chk12 ".W3D 12" pos:[160,270] width:137 height:23
checkbox chk13 ".FLT 13" pos:[160,290] width:137 height:23
checkbox chk14 ".OBJ 14" pos:[160,310] width:137 height:23 checked:true
checkbox chk15 ".HTR 15" pos:[160,330] width:137 height:23
checkbox chk16 ".ASE 16" pos:[160,350] width:137 height:23
checkbox chk17 ".WRL 17" pos:[160,370] width:137 height:23
checkbox chk18 ".DWF 18" pos:[160,390] width:137 height:23
--BUTTON
on btn_Test pressed do(
Array_chkboxes=#() --Empty array
for i in 0 to 18 do(
x = "chk" + i as string
print x
if x.checked == true then(
append x array_chkboxes
print array_chkboxes
createdialog Test
Thank you :)
-Maarten
You're trying to access a parameter of a string value (i.e. of the name of the checkbox control), not the control itself. Also note that there's rollout.controls array that will give you the list of all the controls of the rollout. Something like this should get you started (untested but in the worst case you'll have something to dissect and analyze):
