Now how would I go about doing this.
I'm trying to randomly rotate the position of each arc 90 degrees from the previous arch. Trying to make it look like something similar to the image below.
clearlistener()
delete objects
local radiusA = 10.0
local steps = 4
local knotsPerArch = 6
local rotAngle = 180.0 / knotsPerArch
local startPos = [0,0,0]
local sp = splineShape wirecolor:yellow
local posArr = #()
fn shuffleIndexes count = --unique Random order
list = #()
list.count = count
for k = 1 to count do
i = random 1 k
list[k] = list[i]
list[i] = k
return list
addnewSpline sp
addKnot sp 1 #corner #curve sp.pos --first knot created at origin
for s = 1 to steps do
format "Arch: %\n" s
ids = shuffleIndexes 3
for k = 2 to knotsPerArch+1 do --skip first knot which is always created at origin
calcX = radiusA * cos((k-1) * rotAngle)
calcY = radiusA * sin((k-1)* rotAngle)
pos = [0,calcX,calcY] + startPos --include nodes matrix
newPos = [pos[ids[1]],pos[ids[2]],pos[ids[3]]]
append posArr pos
point pos:newPos size:2 wirecolor:(red/(s as float))
startPos += [0,(radiusA*2),0]
or maybe this
delete objects
local splKnots = 5, kAngle = 180.0 / (splKnots-1), num = 10, origin = [0,0,0], allArchs = #()
for s = 1 to num do
radius = random 5.0 10.0
spl = splineShape name:(uniqueName "ArcShape") wirecolor:(random [50,50,50] [255,255,255]) pos:origin isSelected:off
addNewSpline spl
for v = 1 to splKnots do
calcX = radius * cos((v-1) * kAngle)
calcY = radius * sin((v-1)* kAngle)
pos = [calcX,calcY,0]
if v == 1 do origin -= pos
addKnot spl 1 #smooth #curve (pos + origin)
updateShape spl
origin = getKnotPoint spl 1 (numKnots spl)
if (cnt = allArchs.count) != 0 do spl.parent = allArchs[cnt]
append allArchs spl
angArr = #((EulerAngles 0 90 0),(EulerAngles 0 -90 0),(EulerAngles 90 0 0),(EulerAngles -90 0 0))
for m = 2 to allArchs.count do (in coordsys parent rotate allArchs[m] angArr[random 1 4])
closer
delete objects
local columns = 9
local columnAngle = 180.0 / (columns-1)
local steps = 6
local origin = [0,0,0]
local allArchs = #()
/*Set Vertices*/
local radius = random 5.0 10.0
local col = random [150,150,150] [255,255,255]
local archArr = #()
for v = 1 to columns do
calcX = radius * cos((v-1) * columnAngle)
calcY = radius * sin((v-1)* columnAngle)
pos = [0,calcX,calcY]--include nodes matrix
if v == 1 do origin = [0,0,0] - pos
setPos = pos + origin
p = point pos:setPos size:2 wirecolor:col
append archArr p
append allArchs archArr
/*Offset Vertices*/
clearlistener()
for a=2 to allArchs.count do
preArcSet = allArchs[a-1]
arcSet = allArchs[a]
calcOffset = arcSet[1].pos - preArcSet[columns].pos
for p in arcSet do
p.pos -= calcOffset
delete objects
local columns = 9
local steps = 5
/*Set Vertices*/
local archArr = #()
num = v-1
calcX = radius * cos((num) * columnAngle)
calcY = radius * sin((num)* columnAngle)
pos = [calcX,calcY,0]--include nodes matrix
case of (
(s == 1 and v == 1): archArr[v] = point pos:setPos size:2 wirecolor:col
(s > 1 and v == 1): in ((allArchs[s-1])[allArchs[s-1].count]) (archArr[v] = point pos:setPos size:2 wirecolor:col)
default: in archArr[v-1] (archArr[v] = point pos:setPos size:2 wirecolor:col)
origin = archArr[columns].pos
for m = 2 to allArchs.count do (in coordsys parent rotate allArchs[m][1] angArr[random 1 4])
Try to create separate arrays for the every arch points.(multidimensional array)
Then in coordsys of first point in array change transform (rotation) of other points.
Use rotate "about" first point in array. In your examle you have 4 arrays with 6 points.You can to start from last array:
--rotate about point[19] others (21,22,23,24,25)
--then about point[13] others (14..25) etc.
