Hi all
Reading this question:
http://www.scriptspot.com/forums/3ds-max/general-scripting/script-to-fin…
I enjoyed exploring the script by creating an image reader with relevant information (to study a little MAXScript).
All right, so the script works ecc, BUT... Run this script:
try (destroydialog ::fmi) catch()
rollout fmi "Find Info Image"
Global Sel_Bitmap, new_bitmap, Info
group "Image..."
button bt1 "Select Image"
group "Measure Image..."
label lab1 "Width ="
label lab2 "Height ="
group "Preview"
button bt4 "No preview" width:128 height:128 enabled:false
label lab3 ""
group "More info..."
button bt2 "More Info..." enabled:false
button bt3 "Exit"
on bt1 pressed do
Sel_Bitmap = selectbitmap()
if Sel_Bitmap != undefined then
Info = getBitmapInfo Sel_Bitmap
ffp = filenameFromPath
renderWidth = Info[3]
renderHeight = Info[4]
lab1.text = ("Width = " + Info[3] as string)
lab2.text = ("Height = " + Info[4] as string)
lab3.text = ffp (Sel_Bitmap as string)
new_bitmap = bitmap 128 128
cnb = copy Sel_Bitmap new_bitmap
bt4.images = #(new_bitmap,undefined,1,1,1,1,1 )
close cnb
freescenebitmaps()
bt2.enabled = true
bt4.enabled = true
else messagebox "Please, select a Image file..." beep:false title:""
on bt2 pressed do
try (destroydialog ::mi) catch()
rollout mi "More Info image..."
group ""
label lab_07 ""
label lab_01 ""
label lab_02 ""
label lab_03 ""
label lab_04 ""
label lab_05 ""
label lab_06 ""
button clo "Exit"
on clo pressed do destroydialog mi
on mi open do
lab_01.text = "Type File = " + (info[2] as string)
lab_02.text = "Gamma = " + (Sel_Bitmap.gamma as string)
lab_03.text = "Aspect Ratio = " + (Info[7] as string)
lab_04.text = "Nh. Frame = " + (Sel_Bitmap.numframes as string)
lab_05.text = (Info[5] as string) + " Bits/Channel"
lab_06.text = "Alpha channel = " + (Info[9] as string)
lab_07.text = "Location = " + (Info[1] as string)
createdialog mi 600 180
on bt3 pressed do destroydialog fmi
on bt4 pressed do
display Sel_Bitmap
createdialog fmi style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
As you can see, the button image bt4 is not created. If I try with bitmap is all Ok, but with image button nothing.
The bt4.images have needs of a bitmap in the array, so I thought I'd create a new bitmap
and copy the original selected
image on it for fit the measure ("copy" in Bitmap maxscript).
Then with
I have create a new bitmap to use in array for image button.
This same procedure with a bitmap instead of a button, works well. Why I can not see the bitmap in the button?
Any idea?
Thanks for any help
Ok, I have found this my solution:
I've create a temp. bitmap and copy it in image button
