Okay so for some reason I need to have the plugin installed into the plugin directory and the scripts/startup directory for the plugin to work properly. pretty much having it only in one of the locations does not allow it to set a global variable (only need the global for a split second before i localize them). Anyone ever run into this issue?
An oddball bug with a modifier plugin.
By MKlejnowski · 2013-02-25
In my opinion, if some script regardless of is it a plugin or not, need to run twice to work, then for sure there is a logical mistake inside the code.
Yeah your right. Just as i finish reading your post I found my problem. LOL words of wisdom.
