Hi Everyone,
first post, with hopefully a simple question:
I can't seem to make alignPivot function work
extract from the help:
"Same as Hierarchy/Pivot/Affect Pivot Only - Align to Object."
the help doesn't provide any example unfortunatly.
I tried to select an object in the scene then type alignPivot $otherObject. It return true, but did not do anything.
My problem is that for this function to work, I need to provide two nodes, the source and the target, but the function signature only has one variable... how to how define the second node?
I can't find any example when I google for it...
Does any one know how to use this function within a script?
Thanks!
Jean
try this:
obviously, alignFrom and alignTo are the objects you want to use.
or wrap it in a handy function:
There's no such thing as a scale for a pivot point, so, you should be ok with this.
enjoy,
Hi Le1setreter
This is only setting the position, but what about the rotation and scale values of the pivot point? I could do without the scale, but after having messed with offsetrot and all that, I still can't figure out how to do it properly.
If there is another way to align a pivot transform of a node to another, I am all hear, but if there is a function already documented, maybe this would be better.
Bye,
Jean
try this:
