Adjusting Arch & Design Material Parameters within a Blend Material
By TSuess · 2012-08-15
I've hit a roadblock. I am creating a unverisal Ambient Occlusion controller. The following test script works perfectly.
for a in objects do
if (classof a.material == Arch___Design__mi) then
a.material.opts_ao_on = true
a.material.opts_ao_distance = 24
a.material.opts_ao_samples = 24
if (classof a.material == Multimaterial) then
for b = 1 to a.material.numsubs do
if (classof a.material.materialList[b] == Arch___Design__mi) then
a.material.materialList[b].opts_ao_on = true
a.material.materialList[b].opts_ao_distance = 24
a.material.materialList[b].opts_ao_samples = 24
I am able to adjust the parameters of a Arch & Design material within a Multimaterial. What I have not yet figured out is how to do the same within a Blend Material. It seems that something like this should work. See below.
for a in objects do
if (classof a.material == blend) then
can anyone show me the light? Thanks!!
