I've hit a roadblock. I am creating a unverisal Ambient Occlusion controller. The following test script works perfectly.
for a in objects do
if (classof a.material == Arch___Design__mi) then
a.material.opts_ao_on = true
a.material.opts_ao_distance = 24
a.material.opts_ao_samples = 24
if (classof a.material == Multimaterial) then
for b = 1 to a.material.numsubs do
if (classof a.material.materialList[b] == Arch___Design__mi) then
a.material.materialList[b].opts_ao_on = true
a.material.materialList[b].opts_ao_distance = 24
a.material.materialList[b].opts_ao_samples = 24
I am able to adjust the parameters of a Arch & Design material within a Multimaterial. What I have not yet figured out is how to do the same within a Blend Material. It seems that something like this should work. See below.
for a in objects do
if (classof a.material == blend) then
can anyone show me the light? Thanks!!
Try this out. The maxScript Reference says "MultiSubMaterial is obsolete and is visible only for backward compatibility." Hope it works.
Perfect!
Thanks so much MK! Works perfectly!
