I've hit a roadblock. I am creating a unverisal Ambient Occlusion controller. The following test script works perfectly.
for a in objects do
if (classof a.material == Arch___Design__mi) then
a.material.opts_ao_on = true
a.material.opts_ao_distance = 24
a.material.opts_ao_samples = 24
if (classof a.material == Multimaterial) then
for b = 1 to a.material.numsubs do
if (classof a.material.materialList[b] == Arch___Design__mi) then
a.material.materialList[b].opts_ao_on = true
a.material.materialList[b].opts_ao_distance = 24
a.material.materialList[b].opts_ao_samples = 24
I am able to adjust the parameters of a Arch & Design material within a Multimaterial. What I have not yet figured out is how to do the same within a Blend Material. It seems that something like this should work. See below.
for a in objects do
if (classof a.material == blend) then
can anyone show me the light? Thanks!!
Their team provided transformative design ideas and actualized their concepts with impeccable code. Celebrated for their technical abilities and user experience agency, their management skills are equally impressive.
#2 solution
for a in objects do
if (classof a.material == Blend) then
local blendMtl = a.material
for i = 4 to 5 where isKindof blendMtl[i] Arch___Design__mi do
blendMtl[i].opts_ao_on = true
blendMtl[i].opts_ao_distance = 24
blendMtl[i].opts_ao_samples = 24
#1 solution
for a in objects do
if isKindof blendMtl.map1 Arch___Design__mi do
blendMtl.map1.opts_ao_on = true
blendMtl.map1.opts_ao_distance = 24
blendMtl.map1.opts_ao_samples = 24
if isKindof blendMtl.map2 Arch___Design__mi do
blendMtl.map2.opts_ao_on = true
blendMtl.map2.opts_ao_distance = 24
blendMtl.map2.opts_ao_samples = 24
