addrollout _not_ as floater
By RBX775 · 2008-09-28
Greetings to all maxscripters :)
Hope someone can help me with solving this little problem :
I want to change the content of a rollout (which is in the script window) by choosing an option from a given dropdownlist.
so my first attempt was something like this :
(taken from the maxscript help documentation)
rci = rolloutCreator "myRollout" "My Rollout"
rci.begin()
rci.addControl #button #myButton "My Button"
rci.addHandler #myButton #pressed filter:on codeStr:"MessageBox @Isn't this cool@ title:@Wow@"
createDialog (rci.end())
it could had been wunderful with "rolloutcreator" but i couldnt find a way
to avoid it from opening in a new window(floater).
[IMG]http://www.scriptspot.com/files/dont_want_this_window_with_rolloutcreato…[/IMG]
so my thought was that i just use "removerollout" and "addrollout" instead, but only if "addrollout myrolloutwithallcontens" can open my rollout with all the elements like buttons, labels etc in it...
second attempt :
(also taken but modified from maxscript help docu)
rollout first_rollout "1st Rollout" category:2
label rights "First"
rollout third_rollout "3rd Rollout" category:1
label thirdl "third"
rollout second_rollout "2nd Rollout" category:1
label second "Second"
dropdownlist Technique "select Technique" items:#("","create 'third_rollout'","delete 'third_rollout'")
on Technique selected itm do
If itm == 2 do
addrollout third_rollout
If itm == 3 do
removerollout third_rollout
rf = newRolloutFloater "Rollout Order Test" 200 240
addRollout first_rollout rf
addRollout second_rollout rf
addrollout third_rollout rf
Now the problem is, after i deleted "3rd rollout", i cant add/open it anymore
by selcting the second choice from the dropdownlist...
[IMG]http://www.scriptspot.com/files/no_add_after_pressing_createthirdrollout…[/IMG]
the second maxscript defines the best what i want.
I just want an interactive scipt were the choice made in the dropdownlist can change the look/options of the mainscript, but i dont want a new floating window.
So if somebody has a good plan or even little ideas i would be extra happy !
thank you :)
RBX775
ok, i finally got the idea of "addrollout"
Everything is fine now, maybe this can help someone else (as beginner, just like me) who got this little question :
rci.begin()
addrollout (rci.end()) --will add a new rollout on the bottom of the script
thanks for reading anyways .
