Hey,
I am trying to add simulation properties (0 for collsion, 1 for cloth) to objects in a cloth modifier I have on a plane object. I can add the objects to the modifier but when I try to set whether they are a collision object or a cloth object I get the following error when running the script: --Runtime error: Error, object is not part of simulation
Any ideas on how to fix this because I have no clue at this stage!
this works for me:
"0" is inactive, "1" is collision object and "2" is cloth object
post the code you got so far if you still need help with it, then others have less work to do while fixing it
