Hi!
Does anyone know if it's possible to add a note to a material. Not like a map. More like info stored in the material library file.
Thanks!
By Andreas · 2013-04-17
Hi!
Thanks!
Comments (8)
This is great!
But if I use example#2 and at a later time wan't to access the note how do I do that? I tried a few ways but I can't seem to get it to work.
Thanks so much for your help!
What do you try?
First I add the ca to the material, then I add it to a matlib and saves it. At a later time I wan't to load that matlib and access the note and print it to a edittext
I'm trying to access the note with custAttributes.get mat materialNote but all I get is undefined
Let's say you put material from the library which already have note inside to material slot 3.
Now to get note simply use
If you assigne that material to en object (Box001 for example) then you can use
And to set new note just do
That was easy! Thanks again!
Thanks for the reply!
I'm going to look at it today.
example #2 (visible notes)
Also you can add new rollout inside any material
--CA definition
materialNote = attributes mtlNote
parameters notesParm rollout:notesRoll
note type:#string ui:et_note
rollout notesRoll "Material Note"
edittext et_note height:100
-- example (you can use any material from ME, from object, from library)
mtl = meditMaterials[1]
-- the next line will assigne new rollout to material only if not exists
if not (isProperty mtl #mtlNote) do custAttributes.add mtl materialNote
-- now you can get/set some text
mtl.mtlNote.note = "Standard gray material"
--or if you want to extend existing note
mtl.mtlNote.note += "\nStandard gray material"
-- open material editor and look "Material Note" rollout inside first matrial.
example (hidden notes)
-- define and store note in variable
txt = "This is a custom material note text.\nCheck similar example in MXS Help."
--define custom attributes to hold main function
fn getNote = (format "Note: %\n" txt)
--assigne CA to material
-- now to get note you need first to get material CA
ca = custAttributes.get mtl materialNote
-- then check if ca exists but if not send a message
if ca != undefined then ca.getNote() else messageBox "This material not have any note!" title:"MaterialNote" beep:off
