Hi, I try to add functions to this script (https://www.scriptspot.com/3ds-max/scripts/vraymtl-color-correction), but it doesn't work, help pls
local createColorCorrection = on
local matDiffArr = #()
local matTransArr = #()
local matBumpArr = #()
local matglossArr = #()
local matIllumArr = #()
local matOpacArr = #()
local trans = TranslcencyCheckbox.checked
local diff = DiffuseCheckbox.checked
local bump = BumpCheckbox.checked
local gloss = GlossinessCheckbox.checked
local selfillum = SelfIllumChekbox.checked
fn getmatArr curArr RenderMat texmap_Slot Slot_Color =
for o in selection where o.material != undefined do
join curArr (getClassInstances RenderMat target:o.material)
makeUniqueArray curArr
for mat in curArr do
if mat.texmap_Slot != undefined and isKindOf mat.texmap_Slot Color_Correction do
createColorCorrection = off
exit
)---check for already existing ColorCorrect if it finds one it avoid add a new one
if createColorCorrection do
local cc = Color_Correction ()
cc.color = mat.Slot_Color
newMat = copy mat
newMat.name = mat.name
newMat.texmap_Slot = copy cc
if newMat.texmap_Slot != undefined do
newMat.texmap_Slot.map = mat.texmap_Slot
newMat.texmap_Slot.saturation = Saturationval.value
newMat.texmap_Slot.hueShift = hueShiftval.value
newMat.texmap_Slot.gammaRGB = gammaRGBval.value
newMat.texmap_Slot.pivotRGB = pivotRGBval.value
newMat.texmap_Slot.liftRGB = liftRGBval.value
newMat.texmap_Slot.brightness = brightval.value
newMat.texmap_Slot.contrast = contrastval.value
if Invertrb.state == 1 then
newMat.texmap_Slot.rewireMode = 0
newMat.texmap_Slot.rewireMode = 2
if lightnessrb.state == 1 then
newMat.texmap_Slot.lightnessMode = 0
newMat.texmap_Slot.lightnessMode = 1
replaceInstances mat newMat
---------------------------------------------------Diffuse----------------------------—
if diff do
try ( with redraw off
getmatArr matDiffArr VrayMtl texmap_diffuse diffuse
redrawViews()
) catch()
Показать список оценивших
what are the functions you'd like to add?
I have added some selection options and have rewritten the script it was one of my first script and was not very well written...
The new version is still messy but might be easier to modify, you can find it here:
http://www.scriptspot.com/3ds-max/scripts/vraymtl-color-correction
