Hey everybody!
I am working on a script based level design suite for an old idtech3 based game.
I have a large amount of repetitive GUI Elements that are common to many entities and I thought it'd be far more elegant if I could reference an external rollout in these classes instead of having to rewrite the same cod for each and every one of them.
But since I'm fairly new to Maxscript and I could not find a lot of information about this on the docs, My question is: how would I do that?
The Following Code snippet is one my Entity Class Definitions.
I would like to "outsource" then Spawnflag related Rollout Control elements along with the related functions to a "global rollout" that I can reference as a sub rollout.
--rootScene.MP_SpawnflagSets is a 2-Dimensional array that holds the label information for entity Spawnflags sorted into unique Sets.
MPmisc_modelCA = attributes MPmisc_model ( -----start off MPmisc_modelCA
parameters keys rollout:MPmisc_modelRO
classname default:"misc_model" type:#string
spawnflags default:"0" type:#string ui:SpawnflagVal
model type:#string ui:et_model
angles default:"0 0 0" type:#string
modelscale_vec default:"0 0 0" type:#string
origin default:"0 0 0" type:#string
_rs type:#integer ui:spinner_rs default:1
_cs type:#integer ui:spinner_cs default:1
rollout MPmisc_modelRO "misc_model properties"
checkbox 'spfl_1' "1" offset:[0,20] across:2 align:#left
checkbox 'spfl_2' "2" offset:[0,20] across:2 align:#left
checkbox 'spfl_3' "3" across:2 align:#left
checkbox 'spfl_4' "4" across:2 align:#left
checkbox 'spfl_5' "5" across:2 align:#left
checkbox 'spfl_6' "6" across:2 align:#left
checkbox 'spfl_7' "7" across:2 align:#left
checkbox 'spfl_8' "8" across:2 align:#left
checkbox 'spfl_9' "9" across:2 align:#left
checkbox 'spfl_10' "10" across:2 align:#left
edittext 'SpawnflagVal' "spawnflags" text:"0" enabled:true labelOnTop:false align:#left align:#left
label 'SpawnflagLbl' "spawnflags 0" align:#left
GroupBox 'grp1' "Spawnflags" pos:[4,7] width:154 height:160 align:#left
fn UpdateFlagText spflset = (
TextArray = execute(rootScene.MP_SpawnflagSets[spflset])
chkbxarr=#()
append chkbxarr spfl_1
append chkbxarr spfl_2
append chkbxarr spfl_3
append chkbxarr spfl_4
append chkbxarr spfl_5
append chkbxarr spfl_6
append chkbxarr spfl_7
append chkbxarr spfl_8
append chkbxarr spfl_9
append chkbxarr spfl_10
for i=1 to 10 do (
id = i as string
obj = "spfl_" + id
if i <= TextArray.count and TextArray[i] != undefined then (
chkbxarr[i].text = TextArray[i]
else (
chkbxarr[i].text = "unused"
chkbxarr[i].enabled = false
fn updateSpawnflagValue = (
chkbxarr=#()
j = 0
for i=1 to 10 do (
if chkbxarr[i].checked == true do j += 2^(i-1)
spflval = j as string
SpawnflagVal.text = spflval
SpawnflagLbl.text = "spawnflags " + spflval
fn FlagChecks = (
chkbxarr=#()
checkVal = spawnflags as integer
for c=10 to 1 by -1 do (
if (checkVal - 2^(c-1)) >= 0 do (
checkVal = checkVal - 2^(c-1)
--format "new checkVal %\n" checkVal
--format "checkbox % is checked\n" c
chkbxarr[c].checked = true
-----start of spawnFlag Checkbox Event Handlers
on spfl_1 changed state do
updateSpawnflagValue()
on spfl_2 changed state do
on spfl_3 changed state do
on spfl_4 changed state do
on spfl_5 changed state do
on spfl_6 changed state do
on spfl_7 changed state do
on spfl_8 changed state do
on spfl_9 changed state do
on spfl_10 changed state do
----end of spawnFlag Checkbox Event Handlers
edittext 'et_model' "model" width:140 height:36 enabled:true labelOnTop:true align:#left
button 'b_model' "Browse..." width:60 height:18 align:#left
spinner 'spinner_rs' "recieve Shadows " align:#right fieldwidth:30 min:0 max:7 default:1 type:#integer
spinner 'spinner_cs' "cast Shadows" align:#right fieldwidth:30 min:0 max:7 default:1 type:#integer
on MPmisc_modelRO open do
UpdateFlagText(17)
SpawnflagVal.visible = false
SpawnflagLbl.caption = "spawnflags "+SpawnflagVal.text
--if _rs != 1 then spinner_rs.checked = true else chkbx_rs.checked = false
--if _cs != 1 then chkbx_cs.checked = true else chkbx_cs.checked = false
FlagChecks()
on b_model pressed do
ep = getOpenFileName caption:"Open A Model File:"
rp = substituteString (subString ep ((findString ep "base")+5) -1) "\\" "/"
et_model.text = rp
on chkbx_rs changed state do
if chkbx_rs.checked == true then _rs = 1 else _rs = 0
on chkbx_cs changed state do
if chkbx_cs.checked == true then _cs = 1 else _cs = 0
) ----end of MPmisc_modelCACould anyone here give me an example of how to implement something like this?
