Hello , i have been looking for a solution to this for about two weeks , see;
its about "3d world interiors" and "interior packs" that has been wondering around...
they have textures in chinese alphabet and 3dsmax cant read them ,
the materials all appear as gray and map slots show" JPEG" instead of the actual chinese.jpg.
how can i add chinese language support to 3ds max? should i find a chinese 3dsmax version to open them? even if i manage to open them in some chinese max, i will have to rename all maps to latin alpabet for using them on a projects,
can i do the "renaming" process with a script than can convert chinese alphabet?
ps: windows can read chinese text as i added " install support for eastern languages" when setting up windows so the only problem occurs on 3dsmax's side.
thanks for suggestions , especially those make sense.
you are right partially ,
in the midle of post i wrote about a script that changes texture map's filenames and assigns them to mats with new filename...
i want to create packed scenes with evermotion's system
I guess asking for help about this into Autodesk forum might give you more chances for good replies:
http://area.autodesk.com/forum/autodesk-3ds-max/
