Add a modifier to any object and change its parameter
By Richard Minh le · 2014-10-17
Thanks in advance for your time.
Could I ask how I can make a script that allows me to add an UVW map modifier to any object and have the Box type and Real World Map size turned on.
Similarly, I need to add Shell modifier to any object and have both inner and outer amount to 0.005.
Thank you very much.
Richard,
brttd
Check the maxscript documentation:
docs.autodesk.com/3DSMAX/16/ENU/MAXScript-Help/
obj = $
addModifier obj (uvwMap())
obj.uvwMap.mapType = 4
obj.uvwMap.realWorldMapSize = true
addmodifier obj (shell())
obj.shell.innerAmount = 0.005
obj.shell.outerAmount = 0.005
