I have smpile problem but none of my ideas won't work.
How to activate button(make it execute) in my rollout by another buttion.
Bellow example, btn6 should activate btn5, I already try with .checked=true, state=true, enabled= true but it don't work and I have to press and execute button:
rollout unnamedRollout "Untitled" width:162 height:300
button btn5 "messagebox" pos:[28,28] width:90 height:30
button btn6 "accesor" pos:[36,79] width:84 height:38
on btn5 pressed do
messagebox "it work"
on btn6 pressed do
UIAccessor.PressButton btn5 -- press the button
createdialog unnamedRollout
Thank You
Great, thank You, work perfect.
Most important thing here is to declare your tool variable as global
or in one line with "::"
Now your code need to look like this
try(destroyDialog ::unnamedRollout)catch()
on btn5 pressed do
on btn6 pressed do
unnamedRollout.btn5.pressed() -- press the button
createdialog unnamedRollout 162 300 10 110 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
What do you want to achieve with this ?
