Access Attribute Holder Rollout Controls from external function not working
By Hernan Rodenstein · 2015-05-27
Hi everybody! Can anyone tell me why the function 'enableControl' is not working in this code?:
pt = Point()
addModifier pt (EmptyModifier())
myCA = attributes myData
    parameters main rollout:myRollout
        myParam type:#boolean ui:ckbMyParam default:false
    rollout myRollout "My Parameters"
        checkbox ckbMyParam "My Param" enabled:false
custAttributes.add pt.modifiers[#Attribute_Holder] myCA
function enableControl obj =
	obj.modifiers[#Attribute_Holder].myData.myRollout.ckbMyParam.enabled = true
enableControl pt
Thanks!
Comments (7)
wtgthnmj
i also think that the re selecting will get it to its previous state, but not 100 percent sure...!
Reply to wtgthnmj
pixamoon
actualy it was working after reselection, but not after saving and reopen...
Not wit should save setting, and load on reopen max file:
pt = Point()
        myParam type:#boolean ui:ckbMyParam default:false enabled:false
	ckbMyParam_On type:#boolean
        checkbox ckbMyParam "My Param" enabled:(if ckbMyParam_On != undefined then ckbMyParam_On else false)
function enableControl obj a =
	obj.modifiers[#Attribute_Holder].myData.myRollout.ckbMyParam.enabled = a
	obj.modifiers[#Attribute_Holder].myData.ckbMyParam_On = a
enableControl pt false
Let me know it all works now.
Michele Marcelli
I have not found a solution for my test script... the same problem...
Reply to Michele Marcelli
pixamoon
maybe this will help:
pt = Point()
	local a = (if a == undefined then false else a)
        checkbox ckbMyParam "My Param" enabled:a
	obj.modifiers[#Attribute_Holder].myData.a = a
enableControl pt true
It just store extra local parameter to save on/off
Hope it helps
Pixamoon
Reply to pixamoon
Hernan Rodenstein
That worked OK! Thanks a lot! :)
Just a comment: The first line of the function 'enableControl' now is not necessary. It can be erased.
Thanks Pixamoon!
great :)
I think the line is needed when the object is selected and custom attributes are visible. It just refresh it
Hernan Rodenstein
I realized the script actually works but just temporarily and only if you have the point object selected. When you deselect the object and re-select it again then it goes back to previous state.
Any clue??
