hi guys , i created a script controller for Z position , i want to run script only when my object moves in +Z . i don`t want to use time (to check a value in previous frame and know it rise or not ) , because i need a interactive controller , in time u need to click on play button.
is there any solution ?
Hi vrman, I'll trying to help you.
This Script will create New Spinner controll on base Object and Assign Float Sctipt Controller for Z position.
to use it:
- Create object (ex: Teapot) and select the object First.
then run a script.
- Then Click on play button ... so you can control the speed
by "Hit Speed" Spinner (its animatable if need it).
well.. is this what you need ?
Regards
thank u so much Budi , yes thats what i want .
