If I create a maxscript file with maxscript like this
- f = createFile "C:\a.ms"
- close f
and if I drag and drop the file "a.ms" into max, max will crash.This doesn't happen in max 2011
Also I can't delete the file until I close max 2012 because it says that it is open in 3ds max.
can somebody explain why this is happening in 2012 and how to fix it
thanks.
I also found that maxscript can't create file in c:\, but it can create files in c:\folder_name\. Don't know why.
I use dot net streamwriter and streamreader to circumvent this problem. It seems in every max version there's a different bug going on with the openfile/createfile functions.
did you try flushing? works for toilets ;)
Le bug est corrigé avec l'install du premier hotfix de max 2012 :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=1703236…
Seems like a similar bug posted on The Area. http://area.autodesk.com/forum/autodesk-3ds-max/autodesk-3ds-max--3ds-ma…
