2 entries in a single line in listview!
By artrender · 2013-02-17
Comments (11)
artrender
Thanks, Swordslayer, Now it's working even faster!
No need to make it faster!
I want to change point 3 - make the last row wider like in the picture bellow, and I would like aslo to make my datagrid window rescalebale like in ZOA_PATH_editor.(My script window is allready resizing at it remebers the last changes)
It has a function for listview like that:
	fn re_size arg=
		lv.width=arg[1]-10
		lv.Columns.item[0].width=floor (300*(lv.width-17)/640)
		lv.Columns.item[1].width=floor (140*(lv.width-17)/640)
		lv.Columns.item[2].width=floor (60*(lv.width-17)/640)
		lv.Columns.item[3].width=floor (60*(lv.width-17)/640)
		lv.Columns.item[4].width=floor (80*(lv.width-17)/640)
		lv.height=arg[2]-85
		chk_1.pos=[5,arg[2]-75]
		chk_2.pos=[110,arg[2]-75]
		chk_3.pos=[215,arg[2]-75]
		chk_4.pos=[5,arg[2]-50]
		chk_5.pos=[110,arg[2]-50]
		btn_sel.pos=[arg[1]/2+5,arg[2]-75]
		btn_refr.pos=[arg[1]/2+110,arg[2]-75]
		btn_miss.pos=[arg[1]/2+215,arg[2]-75]
		btn_copy.pos=[arg[1]/2+5,arg[2]-50]
		btn_repl.pos=[arg[1]/2+110,arg[2]-50]
		btn_set.pos=[arg[1]/2+215,arg[2]-50]
		old_path.width=floor (arg[1]/2-60)
		old_path.pos=[5, arg[2]-23]
		old_path_browse.pos=[floor (arg[1]/2-50), arg[2]-25]
		get_old_path.pos=[floor (arg[1]/2-25), arg[2]-25]
		new_path.width=floor (arg[1]/2-60)
		new_path.pos=[floor (arg[1]/2+5), arg[2]-23]
		new_path_browse.pos=[(arg[1]-50), arg[2]-25]
		get_new_path.pos=[(arg[1]-25), arg[2]-25]
in my script I have smth like that
	BitmapLister_iso_x = getinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "pos_x" as integer
	BitmapLister_iso_y = getinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "pos_y" as integer
	BitmapLister_size_h = (if (tmp = (getinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "size_h" as integer)) == 0 then 324 else tmp)
	BitmapLister_size_w = (if (tmp = (getinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "size_w" as integer)) == 0 then 152 else tmp)
		on BitmapLister close do
			disable_event()
			setinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "pos_x" ((GetDialogPos BitmapLister).x as string)
			setinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "pos_y" ((GetDialogPos BitmapLister).y as string)
			setinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "size_w" ((GetDialogSize BitmapLister).x as string)
			setinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "size_h" ((GetDialogSize BitmapLister).y as string)
createdialog BitmapLister pos:[BitmapLister_iso_x,BitmapLister_iso_y] height:(BitmapLister_size_h) width:(BitmapLister_size_w) style:#(#style_resizing,#style_sysmenu,#style_titlebar)
Also, how can I detect texture status like in asset tracking?
Reply to artrender
Vojtech Cada
To make the automatic size adjustments work, I'd add
table.AutoSizeColumnsMode = table.AutoSizeColumnsMode.Fill
and also to make the first column autosize
column1.AutoSizeMode = column1.AutoSizeMode.DisplayedCells
As for the last line, you'd need a function called on control resize, something like
	fn resizeLastRow =
		local lastIndex = table.Rows.Count - 1
		local lastRow = table.Rows.Item[lastIndex]
		local height = table.height - table.ColumnHeadersHeight
		for row = 0 to (lastIndex - 1)
			where table.Rows.Item[row].Visible do
				height -= table.Rows.Item[row].Height
		lastRow.height = height
Minus some margins I guess, but I'm sure you will make it work.
Setting the right datagridview control size on dialog resize is pretty straightforward as you only have to care about its width and height. Resizing dialogs like this can become quite tiresome, though, if you want to resize more than just a few controls, save yourself some pain and use maxforms instead, things like anchors will certainly make you a happier person ;)
artrender
THANKS Swordslayer! You're idea is great!!!!
I've tried to put datagrid instead and it works!
But I want to change it a little:
1. remove left header like in the image bellow
2 select whole row (but to be able to select more then one row and to find out the selection, so that I could operate with it)
http://stackoverflow.com/questions/285829/datagridview-how-to-focus-the-…
table.dataGridView.SelectionMode = DataGridViewSelectionMode.FullRowSelect
and
table.SelectionMode = DataGridViewSelectionMode.FullRowSelect
give errors
3. make empty row till the end
4. make it faster if possible http://social.msdn.microsoft.com/Forums/en/csharpgeneral/thread/14407d45… using VirtualMode
http://msdn.microsoft.com/en-us/library/system.windows.forms.datagridvie…
Reply to artrender
Vojtech Cada
The first two are simple: =
table.SelectionMode = table.SelectionMode.FullRowSelect
which is sort of a shorthand for
table.SelectionMode = (dotNetClass "System.Windows.Forms.DataGridViewSelectionMode").FullRowSelect
and
table.RowHeadersVisible = false
The rest.. I will look into it later when I have more than few minutes to spare, however VirtualMode should not really be needed, unless you do some pretty serious stuff.
Vojtech Cada
Using datagridview might be even simpler:
rollout test "Test" width:680
	dotNetControl table "DataGridView" pos:[13,7] width:650 height:100
	on test open do
		table.DefaultCellStyle.WrapMode = (dotNetClass "System.Windows.Forms.DataGridViewTriState").True
		table.DefaultCellStyle.Alignment = table.DefaultCellStyle.Alignment.TopLeft
		table.RowTemplate.Height = 30
		local column1 = dotNetObject "System.Windows.Forms.DataGridViewTextBoxColumn"
		column1.HeaderText = "Multiline"
		column1.Width = 500
		column1.ReadOnly = true
		local column2 = dotNetObject "System.Windows.Forms.DataGridViewTextBoxColumn"
		column2.HeaderText = "Editable"
		table.columns.add column1
		table.columns.add column2
		table.Location = dotNetObject "System.Drawing.Point" 0 0
		table.Rows.Add #(@"\\S003\work_s003\lib\soft\3DSMAX_2012_setup\x\Textures\textures\3_2_11_d.jpg" + "\n" +
			@"Compositematerial\VRayMtl\Diffuse\", "")
createDialog test
Vojtech Cada
Or you can turn grid off and select two lines at a time. For example, in the sample barigazy provided, you could add an event handler and a variable to achieve that:
try(destroyDialog listview_rollout)catch()
rollout listview_rollout "ListView Selected"
	local selecting = false
	on lv_objects ItemSelectionChanged ctrl evnt do
		if NOT selecting do
			selecting = true
			local index = evnt.ItemIndex
			local indexNext = index + (if mod index 2 == 0 then 1 else -1)
			local itemCount = lv_objects.Items.Count - 1
			for i = 0 to itemCount do
				lv_objects.Items.Item[i].Selected = i == index OR i == indexNext
			selecting = false
createDialog listview_rollout 334 200
2 entries in a single line in listview mean something like Entry1 Delimiter Entry2, but you expect multiline entries :) nm, to save width space you can populate ListView with 1st entry (Texture) and when item is selected to display corresponding (by index) value (Map Tree) into EditText ui control.
artrender
may be another idea
I see that in order to simplify the work with textures, there is a lot of time to waste for coding!
Interesting, how to display now path and map tree to be easy for reading and not to take all the monitor! I wanted this way to have a smaller window :(
can you image this info on a single line
Texture: \\S003\work_s003\lib\soft\3DSMAX_2012_setup\x\Textures\textures\3_2_11_d.jpg
MAP TREE: Compositematerial\VRayMtl\Diffuse\
I guess Better ListView is the only solution!
But prices scared me :) (if I make this script for other people too:)
http://www.componentowl.com/pricing-licensing/better-listview
artrender
Thx BOTH
Yes,
TextA\nTextB
of course doesn't help unfortunately!
Vojtech Cada
Unless you are on max 8 or lower, don't use ActiveX controls. To have multiline items like this in a standard .NET listview you would most probably have to write your own control using extended listviewitems - or use some 3rd party one like Better ListView. For a basic listview usage look for example at Scriptspot :: Working Checklist. Good luck.
Reply to Vojtech Cada
To be sure what is the problem with .net LV
local txtArr = #(
#("TextA\nTextB", "TextC", "TextD", "TextE"), \
#("TextA1\nTextB1", "TextC1", "TextD1", "TextE1"), \
#("TextA2\nTextB2", "TextC2", "TextD2", "TextE2"), \
#("TextA3\nTextB3", "TextC3", "TextD3", "TextE3")
fn initListView lv =
lv.gridLines = true
lv.View = (dotNetClass "View").Details
lv.fullRowSelect = true
layout_def = #("TEXT_1", "TEXT_2", "TEXT_3", "TEXT_4")
for i in layout_def do lv.Columns.add i 80 --add column with name and optional width
lv.TileSize = (dotNetObject "System.Drawing.Size" 80 40)
fn fillInSpreadSheet lv arr =
local theRange = #() --array to collect the list items
for i = 1 to arr.count do
li = dotNetObject "ListViewItem" arr[i][1]
sub_li = li.SubItems.add arr[i][2]
sub_li = li.SubItems.add arr[i][3]
sub_li = li.SubItems.add arr[i][4]
append theRange li --we add the list item to the array
lv.Items.AddRange theRange --when done, we populate the ListView
dotNetControl lv_objects "ListView" width:324 height:190 align:#center
on listview_rollout open do
initListView lv_objects
fillInSpreadSheet lv_objects txtArr
