Send Selected's Material to Clean Material Editor
Hey guys,
I just thought of a little script I thought would be fairly easy to code, and potentially useful to many:
Basically, all it would do is grab the material from any selected object, then open it (solo) in an otherwise clean material editor (default materials in all but active slot).
I hate opening a cluttered (and slow-loading) material editor, simply to adjust one texture, and while I've been using MarkD's helpful "MatClean" regularly, a script such as the one I'm suggesting would cut a couple steps out of the process (right-click "Send Selected's Material to Clean Material Editor", vs. open MatClean floater, select "Clean Editor", select "Get Material From Selected".
Well, that's about it in a nutshell. I hope someone finds the idea worthwhile!
Brittnell
OK, so no one seems too
OK, so no one seems too interested in this other than me, so I've gone ahead and tried my (MaxScripting Caveman) hand at doing it myself.
I'm sure the script is janky looking, but it seems to work like I'd expect.
The only thing I'd really like to figure out now, is how to make this available in my viewport quad.
(edit)
Sigh... Now it seems to make Max crash when run. Hmmm...
How about macros.run "Medit
How about
macros.run "Medit Tools" "clear_medit_slots"
MatEditor.Open()
IF selection[1] != undefined AND selection[1].material != undefined DO meditMaterials[1] = selection[1].material
Try to stay off the macro recorder as much as possible... it's better to look for the right commands in the maxscript reference
Wow, that seems a lot
Wow, that seems a lot smoother and stable.
Thanks!
Now I've got two things to figure out:
1) Work with multiple selected objects (sending each object's material to its own slot in a clean editor).
2) Add to right-click quad.
Since I know pretty much 0 about scripting, I think I've got a lot of reading to do!
Cheers!
DO WANT!
I am REALLY interested in something like this! It would definitely speed things up! You could select a group of multiple objects, hit a shortcut key and it puts all of the materials from selected into material editor slots. oh it would be beautiful. I will be trying to setup a script that will do this but it may take a while (pretty new to this). Hope someone else can help!
I made an edit to the other script on this page. This was you can drag and drop it into max and have a button or shortcut key applied to it:
macroScript SelectedMaterialToSlot
category:"MyTools TSN"
buttonText:"TSN_SelecedMaterial"
toolTip:"Send Selected Material to M-Editor Slot"
MatEditor.Open()
DONE
Here you go! Puts materials from multiple objects into material editor. Could be made better. Maybe I'll add some stuff later.
