Select objects by Gbuffer (Object id)
Hi there,
I am kinda new to this script thing. So what i need is to select objects by its Gbuffer Channel or Object ids. A small float with insert field where i can type the object id i want and a butten to start selecting. Id did get a start script but i dont know how to pass this.
select ( for i in objects where i.gBufferChannel == ID collect i )
Thx in advance
ralf
Hi, This puts your code in a
This puts your code in a simple rollout.
Edit it as you want.
Enjoyed looking at your site some great work.
Martin
-- Select by GBuffer.ms
try (destroyDialog GBuff_Roll) catch()
rollout GBuff_Roll "Select by GBuffer ID"
spinner spn_GBuffID "G Buffer ID: " type:#integer width:80
button btn_Select "Select Objects" width:120
label lab_1 "www.martinskinner.co.uk"
on btn_Select pressed do
clearselection ()
select (for o in objects where o.gbufferChannel == spn_GBuffID.value collect o)
createDialog GBuff_Roll 150 70
Thank you very much for that
Thank you very much for that script,you saved me a lot of time. And thank you very much for your comment on our work. Your architecture stuff i very well done :)
cheers
Ralf
http://www.k-arts.de
